1997 Chrysler Grand Voyager Cooling fans
1997 CHRYSLER GRAND VOYAGER
152,000 MILES • 6 CYL • FWD • AUTOMATIC
VANCE MARTIN
Town driving, the engine over heats. Suspect controls for temperture control. Are the fans supposed to cycle whenever the ac is functioning? Thanks! VM.
Aug 8, 2008 at 5:03 PM
BMRFIXIT
  • 19,053 POSTS
ac on fan on yes
check fuses and motor
if all OK suspect the relay on the front fender reinforcement behind the grille
good luck
Aug 8, 2008 at 5:19 PM
VANCE MARTIN
With temp. gauge pegged, no cooling system fan operation. When in motion system is normal temp.
Aug 9, 2008 at 10:45 AM
BMRFIXIT
  • 19,053 POSTS
check for power and ground at the coolant fan motor with the ac on if no power
check the fuses and relay
fan should come on after the AC clutch kick in
u can run a fused wire and check the fan motor this way too
good luck
Aug 9, 2008 at 2:42 PM
