1994 Chysler Grand Voyager transmission delay
1994 CHRYSLER GRAND VOYAGER
132,445 MILES • 6 CYL • 2WD • AUTOMATIC
JONMADRID
when I select any forward gear it take a long time to engage but the works ok, when I select reverse it works instantly, it has plenty of fluid can you help
thanks
Jon
Jul 9, 2008 at 7:52 AM
  • 110,244 POSTS
Hi:
Have you had the trans filter replaced? The filter, if very dirty, can cause problems.
Also, there are seals / O-rings in the trans / valve body that get old and dry out. When that happens, it allows fluid to bypass and requires a longer period of time to actually work.
Let me know what you find. Also, are there any codes in the computer?
Oct 8, 2008 at 6:39 AM
