1994 Chysler Grand Voyager a/c want cool
1994 CHRYSLER GRAND VOYAGER
STEPHEN1
Air Conditioning problem
1994 Chysler Grand Voyager 6 cyl Front Wheel Drive Automatic
Hi. a/c want cool, found that the cooling fan would not come on when the compressor in running. Cooling fan runs when engine gets to proper temp. but will not come on when a/c is turned on. THANKS
May 3, 2008 at 2:57 PM
BMRFIXIT
  • 19,053 POSTS
Start by checking fuses and relays
Hook up gauges to the system and get the system pressure reading
if to low you need to add more 134a to it and check it for leaks
Have an automotive repair question!
Sign up and ask your automotive question !
Jun 13, 2008 at 10:58 PM
