1994 Chrysler Grand Voyager Wont Start
IRISHGRANDMA
  • 1994 CHRYSLER GRAND VOYAGER
  • 6 CYL
  • FWD
  • 135,000 MILES
I'm currently driving my father's van and it stop on me. It wont start, it tries to and I'm been told it is a fuel pump problem. I need help in where to go on this. Is there any way to check to see if it is that?
Tuesday, September 30th, 2008 AT 8:45 PM
LEGITIMATE007
  • 5,121 POSTS
Well if you listen very carefully, when you turn the key from off to on(without starting) you should be able to hear the fuel pump in the gas tank, make a humming noise. Check your fuses first before anyhing. Will it take a jump start? Check all connections, and what ever you do, do not take it to a dealer, they will rip you off with their pricing, it is rediculous. You will also need to check to see if the engine is getting spark and fuel, I will send you a link that will show you the easy way of doing this.
Tuesday, September 30th, 2008 AT 9:08 PM
LEGITIMATE007
  • 5,121 POSTS
Fuel pressure
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Tuesday, September 30th, 2008 AT 9:09 PM
LEGITIMATE007
  • 5,121 POSTS
Here is a link for ignition/spark
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Tuesday, September 30th, 2008 AT 9:10 PM
Related Engine Not Running Content
Car Cranking but Not Starting? Try This
VIDEO
