1994 Chrysler Grand Voyager interchangable parts with other
1994 CHRYSLER GRAND VOYAGER
49ERMARK
Drive Train Axles Bearings problem
1994 Chrysler Grand Voyager All Wheel Drive Automatic
Is the front differential of a 1994 grand votager all wheel drive able to be installed into a 1995 chevrolet astro van all wheel drive ,and actualy work? {If i had anything to donate i would gladly give whatever i had.}If you ever visit the bay area i can offer you a lunch or dinner at the restaurant i work at {Looney"s Southern Bar-B-Que}.At 53rd and Martin Luther King Jr Blvd.in Oakland ,California.my name is Mark.
Mar 27, 2010 at 6:31 PM
CARADIODOC
  • 34,381 POSTS
Not even with the biggest shoe horn you can find. The Chrysler system uses a viscous coupling which allows the rear wheels to rotate at a different speed than the front wheels. The GM system uses a regular transfer case. It can easily be burned out by using tires that aren't the same size. There can even be problems caused by buying two new tires from one batch, then buying two identical tires from the same manufacturer but from a different batch. There are no such concerns with the Chrysler system.
The GM van has a "north / south" engine that sits the normal way in the engine compartment. Chrysler's is an "east / west" front wheel drive system.
caradiodoc
Apr 12, 2010 at 7:11 PM
