1994 Chrysler Grand Voyager
1994 CHRYSLER GRAND VOYAGER
OLDBEENS
Engine Mechanical problem
1994 Chrysler Grand Voyager 6 cyl Front Wheel Drive Automatic
has spark and 45lbs fuel pressure to rail but no start unless i spray startig fluid into throttle body , dosnt seem to be going thru injectors , changed cam @ crankshaft sensors.its a 94 3.3 chry. mini van
Nov 23, 2008 at 5:32 PM
  • 110,244 POSTS
If you follow the injector wires they will plug into a wiring harness. Check to see if there is power going to the injectors. A test light should pulse on and off.
Let me know what you find.
Mar 16, 2009 at 2:29 PM
