1992 Chrysler Grand Voyager Headlight Assembly
140,000 MILES • 6 CYL • FWD • AUTOMATIC
DESMIL
How do I remove the headlight assembly for replacement. The bulb is not the problem. Water has leaked into headlight
4/7/09
Thank you for the reply and solution. I did drill a hole at the bottom of the light. Some water escaped but don't know if all of it did.
Apr 3, 2009 at 3:07 AM
CARADIODOC
  • 34,413 POSTS
Look for two real long bolts going straight down behind the housing. The bolt heads are real small, a 1/8" hex head or T15 or T20 inverted Torx head. Can't remember for sure.
There is a service bulletin for water that involves drilling a small hole in the bottom. You don't HAVE to take the housing out for this.
caradiodoc
Apr 4, 2009 at 10:44 PM
