1992 Chrysler Grand Voyager ABS
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELMO76
All brakes seems to work fine,but everytime i press brakebedal will the red brakelight illuminate on the dash.The brakepump starts and stopping good. The pump starts again when i pushed brakepedal 3-4 times. Should the pump run,if i don`t press brakebedal, and why the red brakelight illuminates on dash when the brakes are applied?? No trouble codes anywhere.
Feb 25, 2009 at 9:14 PM
BMRFIXIT
  • 19,053 POSTS
Check fluid level
check if system need bleeding
check for ABS code
Feb 25, 2009 at 9:35 PM
ELMO76
[quote:f25a805f79="BMRFIXIT"]Check fluid level
check for ABS code[/quote:f25a805f79]
Fluid level ok
no air in the system and there is no error codes.
Feb 25, 2009 at 9:47 PM
BMRFIXIT
  • 19,053 POSTS
When the light is on scan for ABS codes
ABS codes and NOT engine codes.................
it happens only when moving
and in park too ??
Feb 27, 2009 at 10:10 PM
ELMO76
[quote:c0238bf435="BMRFIXIT"]When the light is on scan for ABS codes
and in park too ??[/quote:c0238bf435]
No ABS-codes found.
Yes, it happens moving and park too.
I`m having a new hydralicbooster next week and i hope that would solve the broblem.
Feb 28, 2009 at 2:54 AM
