2005 Chrysler Crossfire How do I change right front headlam
DAVID MORGAN
Electrical problem
2005 Chrysler Crossfire 6 cyl Two Wheel Drive Automatic 40k miles
The right from bulb burned out on my 2005 Crossfire SRT-6. It looks like I need to remove the coolant reservoir in order to get access to the bulb. I removed the two machine screws with the 10mm heads and the reservoir now moves a little now. It is still being held in place by something from below, but I cannot see what it is nor what to do in order to remove the coolant tank.
Thanks,
David
Aug 3, 2008 at 10:41 AM
  • 110,248 POSTS
Hi:
Check from under the car for another bolt. Also, some may be held by a push plug.
Mar 16, 2009 at 9:10 AM
