2004 Chrysler Crossfire Engine stalls
2004 CHRYSLER CROSSFIRE
BIGERIC37
Electrical problem
2004 Chrysler Crossfire 6 cyl Two Wheel Drive Automatic
Engine stalls while driving then will not crank back up for about 30 minutes or so. This started happening all at once. The car showed no signs of trouble. It ran fine up till now. The engine will turn over, but will not crank. What do you think it is?
Jul 16, 2008 at 3:41 AM
  • 110,194 POSTS
Hi:
Has the check engine light come on? If not, have you checked fuel pump pressure? The pump may be going bad.
Here is a HOW TO video for checking pressure. The gauge can be rented from some parts stores. If you can't find one, you can purchase one at the test equipment store on this page.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know if this helps and what you find.
Mar 16, 2009 at 4:25 PM
