2004 Chrysler Crossfire
70,050 MILES • 6 CYL • 2WD • AUTOMATIC
DGSKAGGS
Car will not restart periodically. Let sit several hours and she restarts fine. Also, will die at low speed and not restart for several hours. Do you know the solution?
Feb 7, 2009 at 2:14 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Does check engine light come on?If yes go to Auto Zone or similar have codes read. Then post
If no then will need to determine if it is loss of ignition or fuel.
Let me know
Thanks for donate
Feb 7, 2009 at 6:06 AM
DGSKAGGS
No the check engine light does not come on when it dies at low speed or when it won't restart after driving. I have had the EGR valve replaced as well as the TDC Pick Up Sensor. After it sets for a few hours it runs like a scalded cat. It does not seem to be a fuel starvation problem, almost like the security system has shut the ignition system down. When I Googled Chrysler Crossfire non start problem there was alot of Crossfire owners with the same problem. As with me their Dealer could not find a code problem either. Mine is far from an isolated problem. I love my Crossfire but I just don't trust driving it anymore. Please help if you can. I'll be happy to donate some more money if you find the problem.
Dan Skaggs
502-259-8734 cell
Feb 7, 2009 at 11:09 AM
DOCFIXIT
  • 18,828 POSTS
Hi
been off line couple days. I'll contact a Chrysler Tech and see what I can dig up.
Feb 9, 2009 at 8:28 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Did not get much help other than has heard about no start but no bulletin has been published or recall.
The only thing I found was for key reprograming but that was for no start at all.
If you came to me I would hook up a dianostic scanner. Put it in snapshot mode with key components flaged then drive till she quit. Read scanner maybe get a clue.
Have you tried contacting the factory representative?
Try Chrysler resolution center
Good luck will keep searching if i get something will let you know.
Feb 10, 2009 at 3:37 AM
