1976 Chrysler Cordoba starter relay wiring
1976 CHRYSLER CORDOBA
999,999 MILES • 6 CYL • 2WD • AUTOMATIC
MARIA PEREZ
I need to know how to replace my starter relay. It seems that everytime I go to hook up the battery cable back they spark and if I leave it too long it burns the positive cable can you tell me what I'm doing wrong? the relay has a nut..... then a plastic insert..... then the brown wire coming from my left side I'm assuming it's my negative......then the red cable coming from my positive. What can be causing the sparking?
May 12, 2009 at 8:23 AM
2CARPRO JACK
  • 11,533 POSTS
Is there any way you can send me a pic of it? my software doesnt go back that far, so I cant look at the wiring diagram to tell you.
May 14, 2009 at 12:45 AM
