1997 Chrysler Concorde Overheating
CLEOROSE
Okay so two weeks ago, I bought this car from a little car lot. The guy was a friend of my sisters, otherwise I would have gone elsewhere and we were desperate. We spent 1500 on a 1997 chrsyler concorde with 85000 miles. Went around the block it was fine. SMOOTH. When we are done I drive the car roughly a half mile away almost a 3/4 of a mile thru heavy traffic. The car overheats, HUGE plume of white smoke. The mechanic said it was the radiator. Okay so two days later we pick up the car (no we did not pay for repairs) Some sensor was replaced and supposedly the radiator. We drive home (about 30 miles), the car is parked and two days later when we go to drive it, it overheats after 10 minutes of driving. We discover the radiator is LEAKING alot. So we replace the radiator, the relay fan, the coolant, thermostats twice, transimission oil. So then it was throwing some kind of oil from the coolant resoivoir. SO we replaced that. We have replaced several hoses. Now it no longer leaks radiator stuff, transmission stuff or antifreeze. But the damn thing still overheats. We can drive about five minutes and then the heat goes up. If you press the gas it goes up even more. Have not seen smoke yet but it gets up to the red line on the temp gauge. What on earth could be causing this?
Jul 13, 2007 at 10:55 AM
2015RAY
[quote:f1589bd559="cleorose"]Okay so two weeks ago, I bought this car from a little car lot. The guy was a friend of my sisters, otherwise I would have gone elsewhere and we were desperate. We spent 1500 on a 1997 chrsyler concorde with 85000 miles. Went around the block it was fine. SMOOTH. When we are done I drive the car roughly a half mile away almost a 3/4 of a mile thru heavy traffic. The car overheats, HUGE plume of white smoke. The mechanic said it was the radiator. Okay so two days later we pick up the car (no we did not pay for repairs) Some sensor was replaced and supposedly the radiator. We drive home (about 30 miles), the car is parked and two days later when we go to drive it, it overheats after 10 minutes of driving. We discover the radiator is LEAKING alot. So we replace the radiator, the relay fan, the coolant, thermostats twice, transimission oil. So then it was throwing some kind of oil from the coolant resoivoir. SO we replaced that. We have replaced several hoses. Now it no longer leaks radiator stuff, transmission stuff or antifreeze. But the damn thing still overheats. We can drive about five minutes and then the heat goes up. If you press the gas it goes up even more. Have not seen smoke yet but it gets up to the red line on the temp gauge. What on earth could be causing this?[/quote:f1589bd559]I had the same problem. It was the fuse to the radiator fans, not the fan relay. open your drivers door and pull the fuse cover off and flip it over it will tell you which one is the radiator fan fuse and replace it. This was the last thing I checked, I could not believe this fixed my problem as I went through for months.
Aug 7, 2007 at 2:49 AM
  • 75,988 POSTS
[quote:5700405c1c="cleorose"]Okay so two weeks ago, I bought this car from a little car lot. The guy was a friend of my sisters, otherwise I would have gone elsewhere and we were desperate. We spent 1500 on a 1997 chrsyler concorde with 85000 miles. Went around the block it was fine. SMOOTH. When we are done I drive the car roughly a half mile away almost a 3/4 of a mile thru heavy traffic. The car overheats, HUGE plume of white smoke. The mechanic said it was the radiator. Okay so two days later we pick up the car (no we did not pay for repairs) Some sensor was replaced and supposedly the radiator. We drive home (about 30 miles), the car is parked and two days later when we go to drive it, it overheats after 10 minutes of driving. We discover the radiator is LEAKING alot. So we replace the radiator, the relay fan, the coolant, thermostats twice, transimission oil. So then it was throwing some kind of oil from the coolant resoivoir. SO we replaced that. We have replaced several hoses. Now it no longer leaks radiator stuff, transmission stuff or antifreeze. But the damn thing still overheats. We can drive about five minutes and then the heat goes up. If you press the gas it goes up even more. Have not seen smoke yet but it gets up to the red line on the temp gauge. What on earth could be causing this?[/quote:5700405c1c]
White smoke is a sign of internal leakage it is not an airflow/circulation problem-your burning it-coolant is making its way to the combustion chamber/s.
Get a block and pressure tests, this will confirm it.
Aug 9, 2007 at 9:11 AM
Suggested Repair
Perform a block test and cooling-system pressure test to confirm coolant is leaking into the combustion chambers. Treat the white smoke as evidence of internal leakage rather than only an airflow or circulation problem.
Conversation Summary
The owner of a 1997 Chrysler Concorde reported repeated overheating and a large plume of white smoke shortly after purchase. The radiator, fan relay, coolant, thermostats, hoses, coolant reservoir, and transmission fluid were replaced, but the car still reached the red line within minutes, especially under throttle. Another user suggested checking the radiator fan fuse, while the expert said the white smoke indicated coolant entering the combustion chambers and recommended block and pressure tests.
