I have a 98 Chrysler Concorder and it is leaking around the air bleeder. We want to replace it at home, how do we bleed the cooling system?
Jun 14, 2007 at 3:51 AM
CDJ1967
MEMBER
the manual for a 95 concorde says to fill the system, run it till its warm then stick a small hose to the bleeder valve ond loosen it up, when coolant flows out non stop for a bit tighten it back up,( run the hose into a bucket, avoid getting it on the belts). Also you will need to replace the bleeder to get it to stop leaking.
