2000 Chrysler Concorde P1684 Surging
SHERRY219
My 2000 Chrylser Concorde( 2.7 , 95,000 miles) started surging while driving and dying @ stops. Codes said the TPS (throttle position sensor) was bad. Replaced that,Now code is reading P1684. Replacing the TPS did make the "check engine" light go off, but car is still surging at times although not as bad. Can't seem to find what code P1684 means
Apr 26, 2007 at 4:20 PM
  • 75,988 POSTS
When the last time you disconnected the battery?
P1684 Battery Disconnected Within Last 50 Starts (Chrysler) plus Jeeps
If its a computer charging system regulated type. The computer is probably being given a curve ball thinking the battery is dead and throwing the code.
Have the charging system check
Apr 26, 2007 at 5:01 PM
Suggested Repair
Have the charging system checked. Code P1684 means the battery was disconnected within the last 50 starts; on a computer-regulated charging system, the computer may treat the battery as dead and set the code.
Conversation Summary
The owner of a 2000 Chrysler Concorde reported surging while driving and dying at stops. After replacing the throttle position sensor, the check engine light went off, but milder surging continued and code P1684 appeared. The expert explained that P1684 indicates a recent battery disconnect and recommended checking the charging system.
