2004 Chrysler Concorde engine codes
74,000 MILES • 6 CYL • 2WD • AUTOMATIC
BZAK37
just got a 2004 concord .check engine light came on ,then trans went into 2nd gear .got code 10,no code 10 on the list ?
Mar 21, 2010 at 2:54 AM
CH112063
  • 1,320 POSTS
There is a code 110. Its for the body control module and means an erroneous internal bus communications error. Buy a nice 6-12 volt test light and check both fuse boxes and relay box under the hood, if everything looks ok buy a scanner here. The scanner is great for every car made and you'll always have it. The scan you recieved was a emissions generic scan. A DRBIII can access the TCM to check specific TCM codes. The fluid should be checked also. They had many problems with the software. OK, I hope I helped in some small way, you'll soon find the trouble and the car will be fine.
Mar 21, 2010 at 5:42 PM
