98 Chrysler Concorde NO HEAT NO POWER BREAKS.
KCHERRY78
  • 1998 CHRYSLER CONCORDE
I have a 98 chrysler concorde and I have no heat. It smells like mildew when I turn it on. Also I think my power brakes have went out or are going out. When I step on the peddle it sounds as if air is releasing somewhere. I have to press the peddle all they way down to get my car to even stop. Do you know what's wrong with either of these. What should I look at first. Thank you!
Thursday, September 6th, 2007 AT 2:42 PM
MERLIN2021
  • 17,250 POSTS
Sounds like a vacuum leak, you'll have to find and plug it. One hint is the air sound when braking, look at the check valve on the booster, it should allow air to pass only one way.
Thursday, September 6th, 2007 AT 4:37 PM
