1999 Chrysler Concorde no heat
134,000 MILES • 6 CYL • FWD • AUTOMATIC
CYMBALSMASH
put a new thermostat in and new radiator cap also the heater core hoses are hot and still have no heat and this car has no heater control valve why i dont have heat
Nov 5, 2010 at 4:41 AM
WRENCHTECH
  • 20,758 POSTS
The heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Nov 5, 2010 at 4:44 AM
MADDOG_
Where is the blend door actuator located? I have this same exact problem. Thank you.
Dec 23, 2010 at 5:25 PM
WRENCHTECH
  • 20,758 POSTS
Please start a question of your own.
Dec 23, 2010 at 5:27 PM
