Since owning this car for the past 6 months I've had trouble starting the car. If I turn the key to the on position to allow fuel pressure to build up it starts right away every time, but if I just turn the key and start cranking it cranks about 8 times and then catches and dies. It always starts right away on the second try. I'm thinking that this could be due to a bad check valve on the fuel pump?? I also notice that as soon as the pump stops running there's noise from the fuel tank. I can't say for sure that it's a dripping sound... more like 6 or 7 taps or clicks that slowly fade out within a few seconds. Could this be due to fuel draining back out into the tank through the pump?? Any thoughts on what should do? If it is a pump issue will it cause any damage to just leave it alone?
Mar 15, 2009 at 1:28 PM
