2004 Chrysler Concorde ENGINE WILL CRANK BUT WILL NOT START
2004 CHRYSLER CONCORDE
159,361 MILES • 6 CYL • 2WD • AUTOMATIC
KM6RENALDO
MY WIFE CAME HOME WITH CAR, GOT UP NEXT MORNING AND IT WOULD NOT START, IT TURNS OVER BUT DOESN'T DO ANYTHING. I CHECKED FUEL PUMP FUSE AND IT WAS OK, TOOK OFF GAS CAP AND THAT DID NOT HELP IF THAT WAS SOMETHING YOU WOULD DO ANYWAY. FUEL PUMP SOUND LIKE IT IS COMING ON WHEN I TURN KEY ON TO ACC AND IT GOES THROUGH IT'S CHECKS. CAN YOU HELP?
May 18, 2010 at 1:13 PM
BMRFIXIT
  • 19,053 POSTS
check for spark
try this test
key on ,check engine light should be on
crank engine light should go out if not suspect bad cranksensor
coil is very common failure
also check this page if not sure on how to do a test
https://www.2carpros.com/video.htm
May 18, 2010 at 11:18 PM
