2003 Chrysler Concorde 2003 Chrysler Concord LXI - 3.5 Ltr
KNECHT5376
2003 Chrysler Concorde 99624 miles
Intermittant transmission problem - unit will downshift while running - check engine light comes on - will not shift back up - 3000 RPM at 40 MPH. When I shut the car off and restart it - the car resumes normal operation. I just had the cam position sensor replaced - as that went bad. There is a transaxle code and a transmission pressure code - has anyone had this fixed? What was done?
Nov 29, 2008 at 12:36 AM
DOCFIXIT
  • 18,828 POSTS
What are the codes in P0xxx format?
Nov 29, 2008 at 4:56 AM
