2002 Chrysler Concorde Transmission failure
150,000 MILES • 6 CYL • FWD • AUTOMATIC
2CECIL
I had been showing a MIL code PO700 (740) TCC solenoid problem for the last week or so. I had it checked but nothing showed so we decided the sensor was defective and was sending message in error. Obviously not because I had a failure Saturday night. Immediately before failure I heard what I thought was a gurgling sound that I thought was coming from the heater core, almost instantly I lost my previously normal functioning transmission. After sitting turned off for a few minutes I was able to move the vehicle to a more secure location about 8 or 10 mph and had it towed. How serious might this be? Rebuild or replace?
Feb 22, 2010 at 12:03 AM
  • 110,251 POSTS
IT was in limp mode. It is designed to protect the trans when there is a problem and get you to a repair shop. Based on your description, I can't imagiane that the trans would make that type of sound. Is the trans fluid full and clean? Also, have you checed the TCM?
Feb 27, 2010 at 4:20 PM
