2002 Chrysler Concorde Do you change the Water Pump when ch
145,000 MILES • 6 CYL • FWD • AUTOMATIC
BOOK40
I am in process of changing the timing belt on an 2002 Concorde that i dont belive has been changed. Should i replace the water pump too? Also does the hydraulic timing belt typically go bad? it seems ok, it compresses and extends fine and with force. THanks,
Mar 29, 2009 at 2:21 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2977d3d766="Book40"]Engine Mechanical problem
2002 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 145000 miles
I am in process of changing the timing belt on an 2002 Concorde that i dont belive has been changed. Should i replace the water pump too? Also does the hydraulic timing belt typically go bad? it seems ok, it compresses and extends fine and with force. THanks,[/quote:2977d3d766]
On vehicle that the water pump is run by the timing belt I won't change one without changing the other. So if your water pump is bad I highly recommend changing out all timing components also. And vise versa.
Mar 29, 2009 at 2:25 PM
