2002 Chrysler Concorde
PRLL
when i press the signal lever up or down the signal lights and indicator will blink once maybe twice and stop .When i press the hazard light button on the colum the hazard light and indicators flash 1 to 3 times and stop working .I pulled the one fuse below the dashboard and it was still working not blown..What would be the cause of this problem and ho wcan it be resolved
Jan 4, 2010 at 7:33 AM
CH112063
  • 1,320 POSTS
with the key on, turn the right turn signal on, get out, check both right side bulbs, same with left, if any one bulb is out, just one filament(front or back) this can happen, it sounds remote, but it is possible, the multifunction lever and the hazard switch both signal the body computer, just one filament can throw it off, the BCM controls front and rear relays they switch the bulbs. hope it helps,
Jan 5, 2010 at 11:43 AM
