2002 Chrysler Concorde
2002 CHRYSLER CONCORDE
62,000 MILES • 6 CYL • FWD • AUTOMATIC
TLLRML
MY CAR HAS BEEN IN THE SHOP 4 TIMES IN PAST 3 WEEKS AHD THE VALVE BODY CHANGED AND NOW THEY SAY ITS THE SOLENOID SHIFTER IS THIS IN THE VALVE BODY THEY ALREADY CHANGED OR IS THIS A SEPERATE PART.BEEN TOLD 2 DIFFERENT THINGS PLEASE HELP
Oct 29, 2008 at 6:36 AM
  • 110,240 POSTS
Hi:
I'm not there to see the trans you have and Chrysler used several. However, most of them are seperate. I check a manual and it shows the plug connector on the top right of the trans. Based on what I see I don't think it would be part of the valve body, but it's possible. See if you can locate it and check if you can tell if the switch is external or internal. It's hard to tell from the picture.
Let me know what you find.
PS: I'm not 100% sure I'm looking at the right trans. It's for an 02 COncord.
Nov 5, 2008 at 9:19 AM
