2001 Chrysler Concorde water pump
LNLARK
2001 Chrysler Concorde 6 cyl
is it safe to drive my car if my water pump has a leak in it. i think thats what it is. when i put water in it it slowly drips out the bottom
Mar 10, 2010 at 8:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if the water pump is leaking it is a likely sign that it is about to fail completely. if it does then the engine will overheat and you will be stuck on side of road broke down. i would suggest having it repaired as soon as possible.
Mar 10, 2010 at 8:09 AM
