2001 Chrysler Concorde engine stalls
61,000 MILES • 6 CYL • FWD • AUTOMATIC
GROVER34
my car stalls after it is running for about 15mins. After it cools off it will start again. i thought maybe radiator temperature problem but car never overheats. Could this be a sensor problem?
Mar 22, 2008 at 8:56 AM
JDL
  • 16,098 POSTS
When the problem occurs, are you saying the vehicle cranks good, but, won't start? Have you tried any basic tests? Have a helper crank it while you check for spark at the plugs. Listen for the fuel pump, when you turn the key on. Can you check for troublecodes? Some of the national brand auto stores will check codes for free.
Mar 23, 2008 at 1:35 AM
JDL
  • 16,098 POSTS
I always check for codes, I don't care if the lite comes on or not.
If you can hear the fuel pump run at key on, that's good as far as it goes. You need to check fuel pressure when the vehicle refuses to start.
When the vehicle refuses to start, did you check for spark at the plugs? When the problem occurs, if your missing fuel and spark, that leads in a direction. If you have good spark everywhere, when the problem occurs, then concentrate on the fuel system.
Mar 29, 2008 at 11:12 AM
