Went to start car and it acted like batter is dead but all interior lights heater headlights work. Went to get a new battery to think the old one was low enough to not generate enough spark. Same status as before. The car has a low volume hum after you turn the key to the start position and stays on even when the key is turned off and pulled out. Only disconnecting the positive terminal stops the hum each time this process is repeated. What do I need to do to accurately check this out take it to a dealer or a local repair shop?
Oct 20, 2009 at 2:47 AM
