2001 Chrysler Concorde
KFRITTZ
  • 2001 CHRYSLER CONCORDE
Air Conditioning problem
2001 Chrysler Concorde 6 cyl Front Wheel Drive 70,000 miles
I have a 2001 Chrysler Concorde and my air conditioner is blowing about 70 degrees after a full charge of 134A. When I bought the car a few months ago I had to add refrigerant (to manufacturer's specs) and it worked fine. (Air was blowing about 40 degrees.) It set idle for about 3 weeks and then the discharge air wouldn't get below 70 degrees. I checked and the refrigerant is at the proper level and I still have a discharge air of only 70 degrees. What should I do next?
Ken
Friday, July 11th, 2008 AT 2:27 PM
DOCFIXIT
  • 18,828 POSTS
Well you have a leak in the system that must be identified and repaired. Don't suppose you own a leak detecter? Once leak is repaired system vaccumed down and charged you be cool.
Friday, July 11th, 2008 AT 2:45 PM
