2000 Chrysler Concorde thermostat
KJR515
Heater problem
2000 Chrysler Concorde 6 cyl Front Wheel Drive
after installing a new thermostat it leaks anti freeze from the housing and over heats
Feb 13, 2010 at 7:25 PM
  • 110,251 POSTS
Either you cracked the housing because the t-stat wasn't sitting properly, or the gasket didn't seal because the surfaces wern't cleaned properly or it loose.
Recheck you work. Keep in mind, there is a small lip where the thermostat fits into. If not properly seated it will leak or crack the thermostat.
LEt me know what you find.
Feb 27, 2010 at 4:51 PM
