2000 Chrysler Concorde oil warning light comes on when come
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
MITCHELLT55
My concorde engine oil warning light flickers when i COME TO A STOP OR IN IDDLE WITH OUT REVING. mECHANIC SAYS OIL PRESSURE IS LOW. i CHECKE OIL LEVEL AND LEVEL IS FINE. IS THER A SIMPLE OR EASY FIX?
Jan 6, 2010 at 2:36 PM
  • 75,988 POSTS
Try replacing the oil pressure switch don't work check oil pressure with a mechanical gauge to rule out the oil pump and engine bearings.
Jan 6, 2010 at 4:26 PM
