2000 Chrysler Concorde fuel tank
214,413 MILES • 6 CYL • 4WD • AUTOMATIC
WYCIED
my fuel tank filler neck is loose where you put gas in the car. Unfortunately now, the entire neck is not visible in the fuel tank after driving for a while. I parked the car until i can get it fixed. Is the fuel tank straps broke or something that allowed the gas tank and filler neck to remain in place? Besides, it is screw holes where the filler neck should be connected to the car. I'm afraid to drive it because i think it might blow up. My car is in detroit and i stay in flint and i really want to rig it and drive my car home. What shoiuld i do and whats the main problem
Sep 19, 2009 at 6:40 AM
CH112063
  • 1,320 POSTS
Do not under any circumstances drive it.
Have it towed to your home, shop, or to a graveyard. Be sure the towing service knows and write a note on the car to be sure the driver knows about it. That is the single largest potential for ruining your or someones life. Not worth taking chances for your sake ok. I don't want to see anything unsafe occur. The fuel vapors are so dangerous. Lot of miles and yes the tank straps could be failing.
Sep 21, 2009 at 12:10 PM
