2000 Chrysler Concorde Door Won't Unlock
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVEMCN
Thanks in advance for any help. My 2000 Chrysler Concorde's rear right passenger door lock is stuck in the locked position. And, the interior lock lever won't move from the "locked" position when you try to force it with your hand. I've tried warming up the car, to no avail (in case of ice). Can anyone indicate what the problem/solution might be? Thank you.
Dec 8, 2008 at 1:55 PM
IBEW15
Hi! What did you do to solve this problem. Having exact same problem. Same model, same year, and same door. Thanks!
Jan 24, 2013 at 11:40 AM
