2000 Chrysler Concorde Coolant Leak
2000 CHRYSLER CONCORDE
120,000 MILES • 6 CYL • FWD • AUTOMATIC
BRBART21
Over the last week or so my car has developed a coolant leak. I noticed the leak manifests only after the car has been shut off. I can see when the leak starts and its not alot, maybe half a cup or so. i was wondering if it was the thermostat or the water pump. Your help is greatly appreciated.
Jan 4, 2009 at 10:39 AM
DOCFIXIT
  • 18,828 POSTS
If leak is comming from front of engine then water pump is it. Thermo would leak whlie running. Pumps leak when shut down at first
Jan 5, 2009 at 7:39 AM
BRBART21
[quote="Docfixit"]If leak is comming from front of engine then water pump is it. Thermo would leak whlie running. Pumps leak when shut down at first.
Thank You for your quick response. Actually the leak comes from underneath the car. I thought it might be the thermostat gasket, or maybe even the housing. Any thoughts?
Jan 5, 2009 at 5:30 PM
DOCFIXIT
  • 18,828 POSTS
Have the cooling system pressure tested that will find leak.
Jan 5, 2009 at 11:48 PM
BRBART21
[quote:17e074bbc8="Docfixit"]Have the cooling system pressure tested that will find leak.[/quote:17e074bbc8]
you were correct, it was the water pump, thank you for all of your help. Guess i have a weekend project!
Jan 6, 2009 at 7:55 AM
DOCFIXIT
  • 18,828 POSTS
Yes it is a bit of a job. If you need step by step and pics. click on site at bottom of reply ie. manuals and for $9.95 you get Mitchel on demand
Jan 6, 2009 at 8:00 AM
