2000 Chrysler Concorde Clicks when i try to start
150,000 MILES • 6 CYL • FWD • AUTOMATIC
HATFIEJD
When I try to start my car it gives 1 solid click coming from the starter. Does that mean the starter is bad, or something else?
Oct 7, 2009 at 3:55 PM
CH112063
  • 1,320 POSTS
Usually yes. It has a pull in winding that pulls a copper disk in, connecting the cable power to the motor winding. It could have connection or cable resistance also, which would decrease the power neccesary to start it. The test is called a starter draw test. It usually shows whether it has a bad starter or it is not enough power. ok Although the starter solenoid is the smaller cylinder on the starter motor, it is replaced together as one unit.
Oct 16, 2009 at 3:26 PM
