1999 Chrysler Concorde engine problems
ULTIMATE WARRIOR
  • 1999 CHRYSLER CONCORDE
  • 6 CYL
  • 150,000 MILES
Acts like it will die when switched from p to drive or reverse only if warmed up also if a/c is turn to high. Exhaust fumes constanly as if burning to rich.
Thursday, November 26th, 2009 AT 12:11 PM
CH112063
  • 1,320 POSTS
If an injector is leaking into your cylinders, if your IAC motor is not working, or yout throttle body is dirty, it can run rich. The o2 system should be tested. Usually an engine scanner is the best way, if your motor has been tuned up, and had a new air cleaner installed.
It will only get worse. See the site menu and look under the 'things to check first', 'how does it work' and go from there. Thank-you
Friday, November 27th, 2009 AT 2:49 PM
