1999 Chrysler Concorde Blower motor runs on high even with
169,000 MILES • 6 CYL • FWD • AUTOMATIC
EDMOND
The blower motor on the heat and A/C system runs on high speed only even with the heat and A/C system (Automatic Temp Control) turned off. The only way I can turn the blower motor off is to remove the 30 amp fuse. Everyone tells me the resistor is the problem, but I can't understand how the blower motor is getting power if the system is turned off. Help!
Blown Away.
Feb 16, 2009 at 11:56 PM
2CARPRO JACK
  • 11,533 POSTS
It has an ignition feed straight into it. If it shorted internally it will power the fan all of the time. Check the connector for damage as wel
Feb 17, 2009 at 12:03 AM
