1999 Chrysler Concorde
ARTHELDA
Electrical problem
My left tail light won't light up, I changed the bulb but nothing happened, even swithched it with the right side, bulb works in right side, not in left, but the turn siganl and brake light works on the left one (same bulb) Is there anything I can check? It can't be a fuse can it since the right one works? I don't want to buy the whole taillight assembly if there is something I should check first. Any suggestions?
Jul 20, 2009 at 9:48 AM
  • 110,251 POSTS
The same bulb works for signal, brake lights, and running lights. However, it has two seperate elements in it that work seperately. Have you checked to see if you are getting power to the socket?
Oct 1, 2009 at 3:50 AM
