1998 Chrysler Concorde Window power motor replacement
135,000 MILES • 6 CYL • FWD • AUTOMATIC
DIGGITY5
The window is lifted by a spring loaded, motor driven scissor type actuator. The mechanics of the scissor lift look to be in good order. The window lift switch and wiring has been checked and is good. This brings me to a bad motor. My problem is that I can't seem to get the bad motor off because it is attached with three screws which heads are against the door surface. To get the motor off I have to somehow get the spring loaded scissor actuator off of the door. How do I do this without releasing the spring and or damaging the scissor lift actuator?
Aug 17, 2009 at 4:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_841.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_114.jpg
Aug 17, 2009 at 5:02 PM
