1998 Chrysler Concorde Whistleing under the hood
100,000 MILES • 6 CYL • FWD • AUTOMATIC
RELL2269
Just got the car and had it about 2 weeks. The other day i noticed a very audible whistling sound from under the hood. At idle the sound is barely audible if at all. The sound seems to start low then go to a peak then die down to nothing. The sequence may take 5-10 seconds. It never really goes away even though there may be periods where I cant here it for a few seconds. Doesn't matter how fast or how hard i get on the gas but always more noticeable under acceleration.
One more thing, what would make the rear defroster stop working? Any help would be greatly appreciated.
Morrell
Nov 22, 2008 at 3:02 AM
  • 110,246 POSTS
Hi:
The rear defroster could be the relay. Make sure the fuse is good.
The engine is another question. Make sure the power steering fluid is full, and using a stethoscope, check the alt, water pump, and power steering pump for noise. It could be a bearing. If you have no luck, check for a vacuum leak that could cause a noise.
Let me know what you find.
Nov 23, 2008 at 12:36 PM
