1998 Chrysler Concorde starter
90,800 MILES • 6 CYL • FWD • AUTOMATIC
NYNIGHTS
How can I get the starter out of the car.
May 3, 2008 at 5:40 AM
MERLIN2021
  • 17,250 POSTS
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! use caution removing the last bolt. Install is the reverse of the proceedure!
May 3, 2008 at 6:06 AM
