1998 Chrysler Concorde Oil Pan
JEF2U
Engine Mechanical problem
1998 Chrysler Concorde 6 cyl Front Wheel Drive Automatic
I'm trying to remove the oil pan, I've removed everything according to the manual, however I can't get the pan out. It appears that there is not enough room between frame and the transmission. The manual does not give any additional information, is there a trick I'm missing??
Dec 6, 2008 at 5:38 AM
DOCFIXIT
  • 18,828 POSTS
Have you taken structural collar from transaxle two bolts hold it on.
Dec 6, 2008 at 6:04 AM
