1998 Chrysler Concorde No Warning shut-OFF
105,198 MILES • 6 CYL • FWD • AUTOMATIC
MARY7520
I have a problem with my Chrysler concorde LXI (1998). I have replaced The fuel pump, M.A.P. Sensor, Throttle pedal Sensor. The car idles with no problem but once it gets on the road it cuts off with no warning and will not start. I have used a obd 11 Reader to find out that theses ^ were throwing codes. I have replaced them but have not found the solution. Now with no codes showing, do you know what would be the problem?
Oct 7, 2008 at 9:42 AM
ZACKMAN
  • 4,202 POSTS
What were the codes?
Oct 10, 2008 at 7:43 PM
MARY7520
No codes are showing now, the last one to show was the code for air intake. We tested the PCM, the part is bad so we are going to change the PCM and see if that doesn't fix the problem.
Nov 7, 2008 at 2:42 AM
