1998 Chrysler Concorde fuel, but no fire
98 CONCORDEBLUES
Electrical problem
I have a 98 concorde, a week ago it simply would not start, the engine crankc fine until the battery runs down.. I checked and do have plenty of pressure at fuel rail.. I noticed that after swapping around the relays, radiator, asd, I probed the asd and it reads 12 volts only for a fraction of a second when you turn the key over to start position, but has no voltage while engine cranks.. The speedomeoter, tach, door locks on same ca have worked intermittently for the last 30,000 miles, but car has run fine.. any ideas??
Sep 16, 2009 at 1:08 AM
JDL
  • 16,098 POSTS
What was the color of the wire you checked at the ASD relay? The dark green wire with orange tracer carries voltage to everything the asd relay controls. During initial prime, the computer will ground the asd relay for a couple seconds only if it doesn't see the proper cam and crank signal. I can't tell you the sensor/s are faulty, I'd have to check the sensor wiring circuits.
Sep 16, 2009 at 3:57 AM
