1998 Chrysler Concorde ac/heater
1998 CHRYSLER CONCORDE
124,000 MILES • 6 CYL • FWD • AUTOMATIC
MATTLDILLON
when u turn on ac, the compressor comes on but when u turn up the air it blows warm, someone said the door or switch that opens and closes the ac to the heater is stuck? ac unit was check'd out fine as well as control unit on console
Aug 24, 2010 at 6:38 PM
ERNEST CLARK
  • 1,730 POSTS
It could be in the switch or it could be the blend door. Whoever checked out you a/c system sould've also checked for this.
If you don't have experience with repairing these units, I don't recommend doing it yourself. However, If you are, then let me know and I'll walk you through it.
It is very complicated because you have to remove the dash, center console and many other parts just to get to the unit. (As well as discharging the a/c system)
Sep 10, 2010 at 6:37 AM
