1998 Chrysler Concorde
TRAYPLUS09
Engine Performance problem
1998 Chrysler Concorde 6 cyl Front Wheel Drive Automatic
its Fuel Injected An i want to know how to change the spark plugs an wires on a carbrated car i wolud know because the plugs are right there i just dont for this one
Nov 25, 2009 at 2:00 AM
CH112063
  • 1,320 POSTS
Hi. I know what you mean, but no different. It is intimidating because it's newer looking but if you follow the wires, they are almost the same and changing the plugs are not any harder. You must get the air filter housing, the clips or plastic screws hold the cover, then the bottom of the aircleaner comes off, you'll be able to see it better. 3.5L or 3.3L is easier than a engine mounted sideways. Use the best plugs, and wires, this way you can just do it once.
You'll need tools for it and a long and short extension. With a plug socket, and some spray silicone to spray into the new wires so they come off easier the next time. Step by step, take your time, cold engine work, ok. If you get stuck and need help just ask. One plug and one wire at a time, ok.
Nov 25, 2009 at 1:37 PM
