1997 Chrysler Concorde Over Charging The Battery
1997 CHRYSLER CONCORDE
13,000 MILES • 6 CYL • FWD • AUTOMATIC
KINGSOVER
The battery is being "Over Charged" It`s my understanding that the votage regulator is not contained in the Alternator but instead is in the PCU unite that is located under the Air Clearner Box , right side of engine compartment. The voltage reading across the battery is 16 plus volts.
Check the connectors to the PCU , all clean ,all good .
Question should i replace both PUC & Alternator to correct the over charging problem ???
Aug 25, 2010 at 12:07 PM
Hi kingsover, Welcome to 2carpros and TY for the donation.
Your alternator is producing output voltages but its not being controlled by the regulator which is controlled by the computer-have the computer checked out or replace it as you wish.
Aug 25, 2010 at 12:27 PM
