1997 chrysler concorde
1997 CHRYSLER CONCORDE
JJ72775
I have a 1997 chrysler concorde with 110,000 miles.
Automatic w/ 3.5L motor.
I just had tires replaced.
Prior to and after my tire replacement I experience a bad vibration.
This occurs between 40-60 mph while my foot is on the gas. If I do not have my foot on the gas between these speeds then there is no vibration.
The vibration comes from the front of the car.
Is it the CV joints?
Thank you for your time and help. They are appreciated.
Sincerely
Jaijef
Sep 27, 2007 at 11:38 AM
2CARPRO JACK
  • 11,533 POSTS
Could be, does th efront end make a clunk noise when you saw the wheel back and forth? mCheck the inner tie rod ends, HUGE problem with them.Blow the rubber bushings right out of them
Sep 27, 2007 at 12:50 PM
JJ72775
I had the tie rods replaced in May at the dealership. Will check for clunking noise.
thank you again.
sincerely
jaijef
Sep 28, 2007 at 12:01 AM
