1996 Chrysler Concorde Turn Signal & Hazard Lamps
11,700 MILES • 6 CYL • FWD • AUTOMATIC
DRLKHILL
Every time I turn on my Hazard Flashers it pops the fuse in relay box under the hood. I took it to a mechanic a few months ago and he said to repalce the multi function switch which I did. The turn signals work fine, until I turn on the hazard lamps and it knocks out the main fuse under the hood then nothing, turn signals or hazard flashers work.
Dec 18, 2007 at 8:22 AM
MERLIN2021
  • 17,250 POSTS
My advice is if any bulb has been changed, pull it out and triple check the number and type! Wrong type bulbs will wreak havoc!
Dec 18, 2007 at 8:26 AM
