1996 Chrysler Concorde running hot
1996 CHRYSLER CONCORDE
T.HILL
Engine Cooling problem
1996 Chrysler Concorde 6 cyl Four Wheel Drive Automatic
i recently replaced the water pump on my 96 concorde, i reset the timing but now my car is running hot ... can anyone suggest why? please please help me its my first car
Aug 12, 2010 at 2:29 AM
LEGITIMATE007
  • 5,121 POSTS
well, it could be several things, one is the thermostat, also the engine coolant temperature sensor , and you also need to verify that the fan(s) are coming on both when the car gets hot and when you turn the a/c on. the radiator cap may not be hold the pressure like it should. . make sure your coolant is a 50/50 mix too.
Aug 22, 2010 at 5:46 AM
